I have had two mixtures:
Mixture 1: N2+O2 (air)
Mixture 2: H2O + O2
Since I have not set the appropriate method for density calculation for mixture 2 (initially it was set as ideal gas), the calculated density of mixture 2 was similar as the density of mixture 1. However, right now everything is fine, I have also marked as solved this problem/question.
