SaiD
Could you elaborate your problem a bit more? What do you mean by "it does not allow me to run the calculation"? Does the simulation start and stop due to some error? Or does it not start at all?
In either case, you should be getting some error message.
In your image, I see a question mark next to "Static Structural", so I suspect some value/condition that is required to start the simulation is not defined. Could you expand each of the folders under "Static Structural" and see if there's a question mark next to it? Also check the details of Analysis Settings. Any required value that is missing should be highlighted in yellow in the respective "Details" window.
