Thank you Rob for the reply. I have assigned UDM manually in Fluent. To make sure I wouldn't assign a small UDM number, I assigned a big number (100). However, I am still seeing the same error.
New Post - Reply To: Node xx: Process xxx: Received signal SIGSEGV.
