January 25, 2023 at 3:27 pm
First, thank you very much your feedback.:)
Please find below the specifications:
- laminar (viscous settings)
- I have defined g considering the inclination (i.e., angle) of the channel relative to the horizontal position, namely g for X: g*sin(angle) and for Y=-g*cos(alfa)
- Mixture mutiphase model
Regarding to the BC at the inlet I have had velocity inlet, and at the otlet pressure outlet. I have defined a symmetry BC, and wall BC (for the upper wall, sidewall, and bottom).
Thank you very much in advance your hints.
Although a certain thinning was expected, but not as much (as in the current simulation).
