DrAmine
You can use that Expression to plot it on the surface right away to verify if it is what you expect before even running.
You z varies over that surface the same with y. If you are doing a fit perhaps number of figures is important. if the have the data in tabaluted form (CSV) and spatial then you can aslo directly read a CSV file to apply it at the boundary.
