InternalObjects, as the name implies, are for internal use purposes. These are neither documented nor tested. So it is not recommended to use them in your code as the API may change without any notifications over versions.
Still, if you want to use it, you can use dir(mesh.InternalObject) and/or help(mesh.InternalObject) to get some pointers.
-Aniket
