/* Replace "dll.h" with the name of your header */
#include "user_force.h"
#include
#include
#include
DLLIMPORT void USER_FORCE(int* Mode , int I_Control[100] , float R_Control[100] ,
int* Nstruc , float* Time , float* TimeStep , int* Stage ,
float Position[][6] , float Velocity[][6] , float Cog[][3] ,
float Force[][6] , float Addmass[][6][6] , int* ErrorFlag)
// *** Visual C++ Template
// 1. Uses stdcall calling convention
// 2. Routine name MUST be in upper case
// 3. All parameters are passed as pointers
// Input Parameter Description:
// Mode int* - 0 = Initialisation. This routine is called once with mode 0
// before the simulation. All parameters are as described
// below except for STAGE, which is undefined. FORCES and
// ADDMAS are assumed undefined on exit.
// IERR if set to > 0 on exit will cause
// the simulation to stop.
// 1 = Called during the simulation. FORCE/ADDMAS output expected.
// 99 = Termination. This routine is called once with mode 99
// at the end of the simulation.
// I_Control[100] - User-defined integer control parameters input in .DAT file.
// (int*)
// R_Control[100] - User-defined real control parameters input in .DAT file.
// (float*)
// Nstruc int* - Number of structures in the the simulation
// Time float* - The current time (see Stage below)
// Timestep float* - The current timestep
// Stage int* - The stage of the integration scheme. AQWA time integration is
// based on a 2-stage predictor corrector method. This routine is
// therefore called twice at each timestep, once with STAGE=1 and
// once with STAGE=2. On stage 2 the position and velocity are
// predictions of the position and velocity at TIME. e.g. if the
// initial time is 0.0 and the step 1.0 seconds then calls are as
// follows for the 1st 2 integration steps:
// CALL USER_FORCE(.....,TIME=0.0,TIMESTEP=1,STAGE=1 ...)
// CALL USER_FORCE(.....,TIME=1.0,TIMESTEP=1,STAGE=2 ...)
// CALL USER_FORCE(.....,TIME=1.0,TIMESTEP=2,STAGE=1 ...)
// CALL USER_FORCE(.....,TIME=2.0,TIMESTEP=2,STAGE=2 ...)
// Cog[Nstruc][3] - Position of the Centre of Gravity in the Definition axes.
// Position[Nstruc][6] - Position of the structure in the FRA - angles in radians
// (float*)
// Velocity[Nstruc][6] - Velocity of the structure in the FRA
// (float*) angular velocity in rad/s
// Output Parameter Description:
// Force[Nstruc,6] - Force on the Centre of gravity of the structure. NB: these
// (float) forces are applied in the Fixed Reference axis e.g.
// the surge(X) force is ALWAYS IN THE SAME DIRECTION i.e. in
// the direction of the X fixed reference axis.
// Addmass[Nstruc,6,6]
// (float) - Added mass matrix for each structure. As the value of the
// acceleration is dependent on FORCES, this matrix may be used
// to apply inertia type forces to the structure. This mass
// will be added to the total added mass of the structure at each
// timestep at each stage.
// Errorflag int* - Error flag. The program will abort at any time if this
// error flag is non-zero. The values of the error flag will
// be output in the abort message.
// DECLARATION SECTION
/*indices*/
int i, j; // indices for controlling loops
/* External additional forces*/
float F_ext[6];
float F_gyro[6]; // Gyroscopic Moments (forces will be zero)
for (i = 0; i<6; i++){
F_ext[i] = 0;
F_gyro[i] = 0;
int struc = 0; // Only one structure
/* Inputs from AQUA*/
float Ir = 12 , omega=50 ; // Rotor inertia
float I_rOmega_r[3]; // Rotor second mass moment of inertia in kg m^2
// MODE#0 - Initialise any summing variables/open/create files.
// This mode is executed once before the simulation begins.
if ( *Mode == 0 )
// MODE#1 - On-going - calculation of forces/mass
else if ( *Mode == 1 )
for ( struc = 0 ; struc < *Nstruc ; struc++ )
// Gyroscopic effect calculations
I_rOmega_r[0] = 0;
I_rOmega_r[1] = 0;
I_rOmega_r[2] = Ir*omega;
// Gyroscopic effect module
for (j = 0; j <3; j++){
F_gyro[j] = 0;
F_gyro[j+3] = 0;
// dot product of Velocity with I_rOmega_r
F_gyro[3] = Velocity[struc][4] * I_rOmega_r[2] - Velocity[struc][5] * I_rOmega_r[1];
F_gyro[4] = Velocity[struc][5] * I_rOmega_r[0] - Velocity[struc][3] * I_rOmega_r[2];
F_gyro[5] = Velocity[struc][3] * I_rOmega_r[1] - Velocity[struc][4] * I_rOmega_r[0];
// Sum of all external force
for ( i =0 ; i < 6 ; i++ )
F_ext[i] = F_gyro[i]
for ( i = 0 ; i < 6 ; i++ )
Force[struc][i] += F_ext[i];
for ( j = 0 ; j < 6 ; j++ )
Addmass[struc][i][j] += 0.0;
*ErrorFlag = 0;
// MODE#99 - Termination - Output/print any summaries required/Close Files
// This mode is executed once at the end of the simulation
else if ( *Mode == 99 )
// MODE# ERROR - OUTPUT ERROR MESSAGE
else
return;
BOOL WINAPI DllMain(HINSTANCE hinstDLL,DWORD fdwReason,LPVOID lpvReserved)
switch(fdwReason)
case DLL_PROCESS_ATTACH:
break;
case DLL_PROCESS_DETACH:
break;
case DLL_THREAD_ATTACH:
break;
case DLL_THREAD_DETACH:
break;
/* Return TRUE on success, FALSE on failure */
return TRUE;
