If you want hollow spheres you'll need to create a second register. Patch the first register as all liquid, then patch the second (smaller diameter spheres) as the hollow bit. I assume the void is air?  Note, as you'll need 5-10 cells across the sphere shell and an aspect ratio of 2-ish your mesh is going to be rather large.
