Negative determinant usually means you have a near zero stiffness. Please check you material input; are they in a consistent unit system?
https://www.dynasupport.com/howtos/general/consistent-units
Also, do you have rigid body motion? This could also cause the negative determinant error.
- Yes, you can use *BOUNDARY_SPC_SET to fix the face.
- Yes, you can use *LOAD_NODE_SET.
Let me know how it goes.
Reno.
