Guilin Sun
The sweep is nested for width and length. you will need to be able to output the so-called conversion efficiency from an analysis group, from model or any monitor that has this quqnatity.
Creating nested parameter sweeps
I guess the important thing is to get the conversion efficiency. Do you know its mathematical definition that you can follow and compute it? if so, it should be simple.
