If the number of control points on surface 2 is 25, and I need to apply a force of 4KN to the entire surface 2, then I use the *load node set keyword to apply 0.16KN to the 25 control points (4/25= 0.16) to achieve the effect of applying 4KN to the entire No. 2 surface, is this correct?
