Edrick Kusumo
There were no more errors above the SIGSEV line but there was a text file in the same folder as the case file that said "Node 0 Fatal signal raised sig = Segmentation fault." I looked up this error in the Learning Forum and someone said that it was a RAM problem, so I decided to reduce the mesh and it worked.
