February 1, 2023 at 11:54 am
@Nikhil
I run the simulation based on your recommendation.
The simulation converges. The velocity contours show very big value compared to the the velocity I computed from the flow rate. In addition, when I check the absolute pressure contour, it shows higher value than the entered pressure at the inlet. I was expecting the maximum pressure to be the pressure inlet.
I am wondering why does that happen?
