martin.kocijancic
Hi. I assume you already have the geometry of propeller and mesh. You can set inlet boundary condition to inlet-pressure (keep default p=0) and outlet BC as outlet-pressure. Make sure inlet and outlet are far enough from propeller. Set rotation speed of propeller, you need to guess it. Then run simulation and Fluent will calculate velocity at inlet. Adjust RPMs so that you come close to specified inlet velocity.
