Hi Peter,
Thank you once again for your helpful reply.
Here is the force convergence plot, the purple force convergence line does spend a lot of iterations below the force criterion line. There are no bisections. Would I take larger time increments just by increasing the time step? As of now my time step is 0.004 s for the first step (interference solving) and then 0.001 s for the remaining 5 steps.
Here is the google drive link to the stl file for the stent (thank you so much!):
https://drive.google.com/file/d/1387qqy-jBNqxGq4gxyqpEiyb6yHDNU0V/view?usp=sharing
As of now I checked (Solve Process Settings -> Advanced), and the Max number of utilized cores is 2.
I checked my Windows CPU ( System Information -> Processor) and I believe I have 12 cores, and a clock speed of 2.40GHz.
I checked through the solver output and there was memory required for out-of-core solution, so I'm assuming the computer did not have enough RAM.
Here is the complete text file as well:
https://drive.google.com/file/d/1MC6XSZXTI11x9bnx8bp-BBieHgUAXjlN/view?usp=sharing
Thank you!!! :)
