Biborka Boga
Thank you for your hints. The reason why at this moment I would like to connect two segments, and use the outlet  profile as an inlet BC for the next segment is because I am curious whether we obtain the same results at a constant length of the channel after assigning the outlet profiles as inlet BC.
Can you please provide me information how can I use journals for this purpose? I have alrady worked with journal files for running  simulation (when I have accessed to the cluster), but to be honest at this moment I do not really know how should I use them (for this purpose). Thank you very much in advance.
