You'd need to write journals to read & write case & data files and write then read & apply profiles. If you click into the TUI panel & hit the Enter key you'll see the menus, type in the command & Enter to get to the next level down. Enter will refresh the menu list, and q (Q) takes up up a level. Putting terms into search (top right of Fluent) will also show some of the TUI command paths.
