Sneh Patel
Hi Praneeth,
Before under the "Set Material Override Tab" option in design settings, the option "Enable material override" was unchecked. So I checked that options and reran the simulation. It gave me a "Surface Mest Generation Failed Error". I have attached a few pictures to help you understand the model.
Thank you Praneeth for your help. I would appreciate it if you could help me with this as I have been on this for a while now.
