DrAmine
You wrote that before you were able to compile and to load the compiled libudf. Then something happened on your computer and you cannot compile anymore. Is this correct? Can you check what happened to your computer? In an empty directly where you do just have the simple UDF file and if you compile with Ansys Fluent Built-In Compiler -> Any log files written?
