Guilin Sun
They should be different, since when PML boundary conditions are used, it will truncate the plane wave, causing diffraction.
The correct way for the thin-film type ( layered as you said) is to use periodic BCs. This is becuase they are assumed infinitely long perpendicular to the thickness axis. They are also periodic in principle.
