February 10, 2023 at 6:25 am
You are right, I'm applying the beam connection on the edge of the hole. I will try to use the imprint command in SpaceClaim to generate a circular surface around the hole to use that surface to define the beam connection, in the same way that the video that u showed me.
I have a question about the imprint generation, I know how to do it in planar surfaces but I dont know hot to generate this imprint for curve surface like in the model that i have. Could you say me how to do the imprint in curve surfaces?
Thanks in advance.
