Wow - that's a low reynolds!
Oscillating convergence plots: you may be able to solicit lots of ideas on this.
Your outlet is a short pipe following a complex geometry arrangement which means the flow is unlikely to be fully established and therefore liable to some flctuation at that surface. One trick is sometimes to artificially extend the outlet a little further downstream where the flow might be more established (and therefore settled).
