Have a look in the Learning courses, there are a couple on flow. Then have a look for laminar eddies. Finally, in the laminar model use a few point monitors to get the local velocity values in areas of interest in your model. I suspect the flow is slightly time dependent, and the monitors will help to judge if the solution is changing by enough to alter the results.
