February 13, 2023 at 1:50 pm
The OPEN and WRITE commands are not APDL commands. Please use *CFOPEN and *VWRITE (and *CFCLOSE)
open('frequency_rotation.txt')
write(unit, 'Frequency (Hz) Rotation_X Rotation_Y Rotation_Z')
Also in below do loop I do not see a SET command to change the result set from one mode to another. Use SET command. Also may be you should do *VWRITE inside the DO loop and after *ENDDO use *CFCLOSE
do i = 1, num_freq
*get, my_freq, active,,set,freq
my_rot_x=ROTX(Measure_Pilot)
my_rot_y=ROTY(Measure_Pilot)
my_rot_z=ROTZ(Measure_Pilot)
write(unit, my_freq, my_rot_x, my_rot_y, my_rot_z)
enddo
