In explicit dynamics, you can use *CONTROL_TIMESTEP to specify an initial timestep (this is usually set by the solver) and you can limit the maximum timestep with a load curve (*DEFINE_CURVE) with the LCTM parameter:
Let me know if this helps or not.
Reno.
