C N
When you change the model to incompressible ideal gas , I recommend you set in the operating conditions to activate the gravity acceleration and give negative direction in z axis -9.81m/s . This way the flow may occur against the gravity . Morever the ideal incompressible gas is used for weak compressible gas with temperature dependency and ideal gas accounts for both pressure and temperature effects. Hope this solves your problem
Thanks
