Miguel
Hi Ashish. Thanks for your reply.
No: it´s not shared where I try to establish the contact (leg surfaces end-edges and washer-face):
It is share where it should be, between the leg surfaces and the tip body:
Meanwhile I managed to go ahead with a "trick": I moved the washer 0,1mm away from the edges creating a small gap between them with the idea of establishing contact using the setting "adjust to touch". Apparently it worked (even though this geometric modification setting is not available ¿?):
However I am not very confident about it and not sure this is making a working valid contact...
Any other suggestions/recommendations?
