Praneeth
Hi Molka,
Thank you for reaching out to us and your patience is much appreciated.
Please provide more information on your query to help us serve you better:
  1. Are you using Q3D design type? and which version of AEDT are you using?
  2. What type of solution setup you are using? Did you enable CG setup in the solution?
  3. Did you go through any example or getting started guide?
  4. Kindly share screen shots of your model and the problem you have encountered.
Please use tool info and other details of your simulation model for a quick response in the learning forum. You can also use tags to help us serve you better and faster.
Best regards,
Praneeth.
