I cannot help on that: as mentioned at least two times in this thread the flags are not meant to be exposed on this open forum. You can first assess that TUI way to define the minum particle diameter. You probably won't require that hidden flag for the mass in the newst versions. Just check if lowering the minimum diameter will help particle nucleation.
