SaiD
  1. Could you describe the boundary conditions that you have used in the Static Structural analysis?
  2. Are you implementing element kill and activation in Static Structural analysis too? Or is this only in Transient Thermal Analysis?
  3. Im image 3, the second last Warning talks about an unspecified unit system and the unit system that the solver assumes. Did you check that warning and ensure that the unit system being used is indeed compatible with your problem?
