Aritra Chakraborty
Hi Sheldon, thanks a lot for the replies. I want to do via "Commands (APDL)" because the current exercise is part of a larger problem. The final goal is to specify a temperature function instead of a single value which makes applying such via APDL much convenient.
So for a named selection, I will have different temperature for different elements which is based on the coordinates, that's why I was looking for the APDL commands.
-Aritra
