Sheldon Imaoka
Hi Aritra,
Thanks for your reply.  In that case, if the built-in functionality of Mechanical doesn't serve your needs, you can use the "D" command to impose a known temperature value on nodes (or nodal component) in a thermal analysis.  (BF command is only for imposing temperatures in a structural analysis.)
Sheldon
