February 16, 2023 at 8:16 pm
Hi Sheldon,
Thanks again, and, yes, I tried "D" for a simple case and that works.
Another quick question, the original mechanical geometry has some blocks that are identified as rigid bodies which probably are not supported by the thermal solver.
In that case, can i solve for the temperature field for part of the geometry and use that solution for the subsequent mechanical simulation with the full geometry (i.e., inlcuding the rigid blocks that I suppressed for the thermal solver) ?
-Aritra
