SRP
How did you initialize in both the cases?
I suggest you to start solution with lower time step.Lowering the time step will enhance convergence.If you experience difficulty in getting convergence for desired time step, use lower time step for initial transients, once you get good convergence gradually increase time step to required value.
Thank you
