Guilin Sun
I guess you know where the temperature is, right? it should match the HEAT simulation. In HEAT, the monitor is to record the temperature. After importing in FDE, the temperature will be converted to index change.
You should not arbitrarily change the position.  It is understandable why the result changes. In addition, the temperature monitor may need to be larger.
