Thank you DrAmine, for your answer. My case is with spherical particles; I need to simulate the collisions between particle-particle and particle-wall.
Since this is a spherical particle, should the use of ansys fluent be enough? Or do you consider a better tool to couple with rocky? Why?
Thank you.
