Ricardo Lionar
Hi Rahul,
Tried your suggestions, and the simulations run but encountered an error
Tried looking for a solution to this similar problem:
https://forum.ansys.com/forums/topic/problem-with-ansys-surface-to-surface-enclosure-type/
Turned out that the perfect enclosure can only be applied when the sum of the view factor is one. In this case, the inner surface does not have the "pair". Hence, the error happens.
I guess in the end I need to define the ambient temperature to make this simulation works
Thanks for your help
Ricardo
