Maheswari Gutta
Greetings,
Thank you for the reply. The point profiles are velocities (vx, vy, vz) at (x,y,z). Boundary condition of inlet = velocity (velocity specification method = components). The report is volumetric flow rate at the inlet. The point profiles are generated (and read/applied) at every 0.001 timestep, same as fluent timestep. The convergence criteria are set to 10e-4.
Are the interpolation values calculated at the nodes or cells or facets? I thought they should be at the nodes.
Thank you
