You are using the flexlm port, not the ansyslmd port. The ansyslmd port should be a different port, found on the VENDOR line of the license file. Please try using that port.
Also, the variable is ANSYSLMD_LICENSE_FILE, not ANSYS_LICENSE_FILE
