Suwitcha Titaram
Thank you for your advised. Ok from that damage generate from default program setting.
Could you please explain to me know ? How i can use data or result from explicit funtion ?
Because now i can't finding theory or solution for support to compare result from this program analysis.
I would like to be ensure data from program as same theory.
I only know the animation report and data report from program but can't find the raw solution that program solve from my parameter.
Then i can't judgement what my parameter impact for the result.
Can you recommend some theory or solution that i can reference ?
