Click on the Remote Displacement, and change the Z coordinate to -2000 mm or 2 m depending on your current units setting.  Change the 10 degrees to 20 degrees.
If you want to see the ball get struck by the bat, click on Analysis Settings and in the Output Controls section, change the Result Number of Points to 1000 then Solve.
On the Animation player control, click on the Result Set button (red circle), then click Play.
