Note that when you changed 10 degrees of rotation to 20 degrees, you doubled the velocity of the bat.
Use the Body filter and select the ball then insert a result Deformation > Directional Velocity. Set the direction to the Y axis.
Here is a post about Contact Force vs Time.
