Hi Henri
In the lower right of the UI you posted is a 'Export to Library' option. You can create your materials then export them to a library. Then next time it will show up as a personal library in the upper right (if saved to your personal location).
Ram & Henri - Maxwell uses a library format similar to XML but is not XML.
