Hi David:
The question is difficult to answer without knowing more about the problem that is being solved.
The Chemkin visualizer uses .xml files, which can have some memory issues. There is more information on this in the 2023 R1 Chemkin Pro Visualization manual in the chapter called "Auxiliary Information"
https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v231/en/chemkin_viz/marker-1044481.html
I hope this helps,
Judy
