OK, look at the min/max on the Contour panel, they're all the same. Also, look closely at the scale on the image. The lower value is the same and ties up with the settings panel; the upper value is different but it's also not the final value on the scale.  So, nothing wrong with the results, it's just a difficult option to spot.
Check with Contour 2 alone, having two picked at once in the display can do odd things. If you're using Fluent, do the post processing there.
As an aside, avoid spaces in filenames, directory structures, boundary conditions etc. It's good practice when dealing with engineering software as many codes are UNIX based so may not like spaces or other "odd" characters ( " £ $ { ] ) etc.   Hyphen - and underscore _ are valid.
