February 28, 2023 at 11:56 am
Hello Rob,
I'm having UDM in my UDF but it doesn't give me any value since the case is not even getting initialized. Can you have a good look at my UDF and let me know where I'm wrong? Also, I'm trying to run this in parallel with 4 processors. I'm sharing my actual code here.
Also, is there a way that my udf is causing a cell or value or something similar that doesn't exist is getting written to and Fluent then crashes??
DEFINITION OF MASS SOURCE TERM FOR LIQUID PHASE
DEFINE_SOURCE(liq_src, c, t, ds, eqn)
#if !RP_Host
real m_dot_l, T_sat;
real vol = C_VOLUME(c, t); //SIGNIFIES THE CELL VOLUME FOR A CELL AND THREAD
Thread *pt = THREAD_SUB_THREAD(t, 0); //PRIMARY PHASE THREAD
Thread *st = THREAD_SUB_THREAD(t, 1); //SECONDARY PHASE THREAD
if (C_VOF(c, t) < 0.99 && C_VOF(c, t) > 0.01)
if (C_T(c,pt) >= T_sat)
m_dot_l = -0.1 * C_VOF(c,t) * C_R(c,t) * fabs(C_T(c,t) - T_sat) / T_sat; //LEE EVAPORATION MODEL
ds[eqn] = -0.1 * C_R(c,t) * fabs(C_T(c,t) - T_sat) / T_sat;
else
m_dot_l = 0.1 * C_VOF(c,st) * C_R(c,st) * fabs(T_sat - C_T(c,pt)) / T_sat; //LEE CONDENSATION MODEL
ds[eqn] = 0;
else
m_dot_l = 0;
ds[eqn] = 0;
C_UDMI(c, t, 9) = m_dot_l;
return m_dot_l;
#endif
DEFINITION OF MASS SOURCE TERM FOR VAPOR PHASE
DEFINE_SOURCE(vap_src, c, t, ds,eqn)
#if !RP_Host
real m_dot_v, T_sat;
if (C_VOF(c,t) < 0.99 && C_VOF(c,t) > 0.01)
m_dot_v = 0.1 * C_VOF(c,t) * C_R(c,t) * fabs(T_sat - C_T(c,pt)) / T_sat; //LEE CONDENSATION MODEL
ds[eqn] = 0;
else
m_dot_v = -0.1 * C_VOF(c,t) * C_R(c,t) * fabs(T_sat - C_T(c,pt)) / T_sat; //LEE CONDENSATION MODEL
ds[eqn] = -0.1 * C_R(c,t) * fabs(T_sat - C_T(c,t)) / T_sat;
else
m_dot_v = 0;
ds[eqn] = 0;
C_UDMI(c, t, 10) = m_dot_v;
return m_dot_v;
#endif
DEFINITION OF ENERGY SOURCE TERM FOR BOTH PHASES
DEFINE_SOURCE(enrg_src, c, mix_th, ds, eqn)
#if !RP_Host
real m_dot, T_sat, hfg;
Thread *pt, *st;
pt = THREAD_SUB_THREAD(mix_th, 0);
st = THREAD_SUB_THREAD(mix_th, 1);
if (C_VOF(c, pt) < 0.99 && C_VOF(c, pt) > 0.01)
if (C_T(c, mix_th) >= T_sat)
m_dot = -0.1 * C_VOF(c,pt) * C_R(c,pt) * fabs(C_T(c,pt) - T_sat) / T_sat; //LEE EVAPORATION MODEL
ds[eqn] = -0.1 * C_VOF(c,pt) * C_R(c,pt) / T_sat;
else
m_dot = 0.1 * C_VOF(c,st) * C_R(c,st) * fabs(T_sat - C_T(c,mix_th)) / T_sat; //LEE CONDENSATION MODEL
ds[eqn] = -0.1 * C_VOF(c,st) * C_R(c,st) / T_sat;
else
m_dot = 0;
ds[eqn] = 0;
C_UDMI(c, t, 11) = m_dot;
return hfg * m_dot;
#endif
