Maria Fernanda Velasquez
Greetings Peter
I answer your questions below:
Is this model supposed to represent a real assembly? Yes, it's not built yet, but that's the idea.
Are the parts actually glued together?  The pieces of aluminum are to be joined by welding (like a frame), and the joint between the rubber and aluminum (in the vertical direction) is intended to be made with screws that hold the pieces joined.
I share the link to the .wbpz file
Link: https://drive.google.com/drive/folders/1yJXSX1q9qj3bL5AsGmP6NgsFfwQ8UcAO?usp=share_link
Maria Fernanda
