CHIEH TING WANG
So i was simulate a micro gas turbine the fuel injection was set as mass flow inlet :0.0096 kg/s;mixture fraction set 1;total temperature 300k.And the air was set as mass flow 0.473 kg/s of oxidizer ;total temperature 430k
the speices model i chose [non-premixed combustion chemical equalibrium],after caculation the result temperarure appear over 2000k.so why the temperature can be such high?is there any property burning point can be set?
