Guilin Sun
The profile seems correct. Is the max value in the interpolated the same as the original? since it is interpolated the result may be somewhat averaged. You may also check the script again.
After simulation you have the raw data. You can export the data to the 3rd party tools, provided that they can read the data correctly.
