NAVID SALAM
Hey Petro,
I have done some digging and found out that the UTS is 4MPA. I have attached other material properties below here. The drop height calculated is correct. Is it necessary to provide a lower impact velocity as that specific height is the main concern in my study?
With this failure criterion, is it possible to know the workflow of how I would be able to conduct a smooth double drop with 2 plates dropping on the MPP?
